sprinkler "booster pump"
I am wondering if instead of using "fire pump" I could use a regular water circulating pump to boost domestic water pressure...?
RE: sprinkler "booster pump"
The legal aspect of pumps, and the acceptable arrangements, also changes depending on the system design (NFPA 13 or NFPA 13R or NFPA 13D)..........your options change depending on the applicable standard. Research and time my friend.
Now when technicians see them, they don't know what they are for. Most of the time a a flow switch with a delay has been installed, and the old pump is left in-place. I think they are left "just in case" because most people don't even know what they are.
