Historic Masonry Repair Article?
We frequently get calls to evaluate various problems with older load bearing brick masonry structures, and more often than not, one of the problems is the use of modern cement mortar when re-pointing. Typically, our scope is not such that I can offer solutions beyond "consult a mason familiar with historic masonry materials and methods".
I am looking for a trade article from a journal or magazine that explains the issues well enough that I could offer to the clients to provide a little more explanation and a lot more detail on appropriate materials. I know I've read a couple such articles in the past, perhaps in Old House Journal or Fine Homebuilding or such, but I can't seem to locate any that aren't very technical now.
Thanks in advance,
Patrick
Thanks in advance,
Patrick
RE: Historic Masonry Repair Article?
htt
http
Those are great, and I use them as a reference often, but I was hoping for something more succinct that just provided the basics.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
Unfortunately the term "loadbearing" sends chills up the spine of an uninformed engineer.
If you look at the first note in the Appendix for the ASTM C270 mortar specifications, it clearly points out that there things more important than strength because for masonry walls. I have seen hollow concrete masonry prisms made that tested 4800 psi using 2400 psi mortar (Type S, not even Type M), so that underscores the lack of importance in the strength of loadbearing masonry construction.
You must use the "mortar of the time" that is compatible with materials for a truly balanced finished wall that works in unison and is durable rather than having too strong a different mortar that causes durability problems. For an older, soft brick, a sand/lime mortar could be more desirable.
I think the BIA would be better than the Bricklayers Union, but the union still has some history around despite the low number of masonry restorers in the restoration industry. Most of the problems from restoration come from deterioration/weathering due to incompatibility of materials.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
Dik
Dik
Dik
In my way ov viewing things, all Masonry walls are load bearing in the sense that their weight alone is freqently higher than the load then support, or bear.
I know, picky, picky... neverftheless, just a thought.
Mike McCann
MMC Engineering
