ZeCor material welding
I'm looking for the appropriate welding consumable for ZeCor-Z and ZeCor-310M plates welding having thickness 8mm.
In addition is there any specific condition for preheating or PWHT?
Welding process to be used: GTAW/FCAW  or SAW
Thank you
RE: ZeCor material welding
Use ZeCor welding wire.  Weldability is similar to 304/316 so I don't think you need preheat or PWHT.
No preheat postheat, it is fully austenetic.
too bad it isn't thinner, you could weld autogenous.
You need matching alloy as filler.
Plymouth Tube
