meshing solid45 to hollow cylinder with internal defect
Hi everyone,
I'm new to ansys. I need help from anyone who knows the steps to do the meshing of solid brick 8 node 45 in order to get the brick shape during meshing. The problem is I repeatedly got the tetra shape during meshing even i have select the element of solid brick 8 node 45.
My component is a hollow cylinder with small internal defect and is an imported IGES file.
I have attached a file that illustrate what kind of mesh i need and the tetra shape that i got..
Thanks for all the help.
RE: meshing solid45 to hollow cylinder with internal defect
www.priamengineering.co.uk
good luck
