Copy sketch to another plane
Can I copy one sketch to another plane which is parallel to the sketch plane without loosing its constraints? or fully defined.
RE: Copy sketch to another plane
If said sketch is going to be completely in line with the first sketch, start a sketch on the second plane, select the 'convert entities' tool and simply select the lines of the first sketch that you want.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
... and if the entire sketch is to be copied, select it in the FM and then use the Convert Entities tool.
Click on the first sketch, Ctrl-C, Click on the plane or face, Ctrl-v.
You will have to reconstrain it in rotation and position.  Usually for me it is simply a coincident with the origin and some horizontals and verticals.
I hope this helps.
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
•Select sketch in feature tree
Edit --> Copy (or ctrl-C)
•Select destination face or plane
Edit --> Paste (or ctrl-V)
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Answer to the question is "Yes"
I think your best bet is probably to do a derived sketch, esp if you're going to be making any changes to it.
Thanks Jeff and CBL
This forum is really helpful
