54 inch ?
54 inch ?
Hi all,
looking at ASME B16.47, there is a 54NB flange, where when I look in AMEB31.10M, there is no 54 inch pipe listed, it jumped from 52 to 56 inch.
Could someone please comment on this?
Cheers
Cheers
RE: 54 inch ?
RE: 54 inch ?
RE: 54 inch ?
Perhaps you should get more of a life outside of engineering
Develop new friends..... try new activities
RE: 54 inch ?
RE: 54 inch ?
Where to find a 52 1/2" Diameter flange depends on if you are making both sides of the joint. If you are, I would construct it as a body flange in accordance with Section VIII Division 1 Appendix 2.
