MS20470AD6 - Allowables
Do you know the allowable shear (if possible also tension) value for rivet MS20470AD6 (3/16) with protruding head and sheet thickness 0.05inch (2024T3/T42)?
Mr. Niu provides in his book the tables, but only up to size 5/32 (pg. 286). Btw. the allowables in this book seems to me very conservative (e.g comparing to hand calculated allowables or data acc. Bruhn). Could you recommend another reference than Niu/Bruhn for rivet allowables?
Thanks for support!
Thanks for support!
RE: MS20470AD6 - Allowables
HDBK-5 available at the DOD website. This publication has been superceeded by the MMPDS. Anyway, the values in handbook 5 should still be close.
Cheers
bearing allowable = 955*1.3 = 1141 lbs (not critical)
from McCombs supplement to Bruhn, table A20, tension allowable = 520 lbs
