Rupture Disk holder Code stamped as well?
One of my coworkers has recently been assigned the task of replacing all of the older rupture disks with new Code stamped disks.
But it seems like the system designer is under the impression that one would need to replace the Holder as well.
Are the holders Code stamped, or is it just the disk that is ASME stamped?
I cant remember where, and I cant find it, but I recall that in one of the ASME Codes it states that you must use a holder and disk from the same manufacturer.
Thoughts?
