spot weld on surface body -- "spot welds shares a common node" error
"ERROR ! One or more spot welds shares a common node.
For example, node 159 appears in more than one spot weld. The model should"
The ANSYS message reads like the above.
could anyone tell me what i am not doing right?
what is causing the problem?
it seems like a meshing problem. one lucky mesh didn't cause any problem and i was able to finish the problem. dose this mean meshing differently is the only solution?
