wierd solidworks quirks
One of my coworkers is having a curious issue. He is representing stamping into a part by overlaying a sketch with text on an extrusion. He is not performing an extruded cut to reduce the graphically intensive features on the part. However, when he creates a new drawing, the text comes in substantially smaller on the drawing than in the sketch within the part file.
Any ideas how to fix this?
RE: wierd solidworks quirks
Does the print preview show correctly?
Which version and SP of SW, and which OS are you using?
I'm running SW2011-SP4 on XP Pro x32.
I just did a quick test and the Explode Lines did not show in the detail view.
Its SW 2010 SP3, and running in XP, 32 bit i believe
