conversion of Italian steel material to Canadian or USA Standard
Does anyone know what this steel material is equivlant to in Canada/USA FE510 OR IN UK 50B
STEEEL REQUIRES FOLLOWING CHARACTERISTICS: Failure or> 5200 daN/cm2
Yield os> 3600 daN/cm2
RE: conversion of Italian steel material to Canadian or USA Standard
Anyway this generic indication is commonly used for a structural steel in either plate or beam form.
There is no direct equivalent: you should choose only based on strengths. A537 1 or A737 B are two examples.
prex
motori@xcalcs.com
XcalcS
Online tools for structural design
