SE v20 surface model to solid part problem
Hi everybody! Does someone know if Solid Edge V20 have a tool for converting surface model to solid model which is solid entirely under the surface model? I have tried the Thicken –tool but it only makes "thin walls" inside the surface. I tried also Replace face –tool for solid protrusion (Replacing solid faces to look like surface faces) but that won´t work either. I know that some programs have the feature/tool which fills the surface model inside (for example CATIA has this feature) but is this missing from Solid Edge V20? Many thanks for your help!
RE: SE v20 surface model to solid part problem
Sometimes you have to protrude a 'block' then subtract the surface shape from it.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
