Select group by them name in a journal
Is it possible in a journal to select some groups by them names?
I want to select groups whom the name begin by "post_" in a .sim file.
Bastien
NX7.5.4.4
RE: Select group by them name in a journal
Bastien,
I work for Siemens PLM and know a couple guys familiar with NX Open. I'm ghost writing for them. Without knowing the intent of the group query, here are a couple suggestions from them (i.e. not me):
loop through the groups to find the desired name, i.e.:
        ' Get the base part
        Dim basePart As BasePart = theSession.Parts.BaseWork
        ' Test to ensure it is a SIM part
        If (basePart Is Nothing Or Not TypeOf basePart Is CAE.SimPart) Then
            theNXMessageBox.Show(MessageBoxTitle, NXMessageBox.DialogType.Error, "SIM Part must be loaded")
            Return
        End If
        Dim simPart As CAE.SimPart = CType(basePart, CAE.SimPart)
        For Each caeGroup As CAE.CaeGroup In simPart.CaeGroups.ToArray
            If Left(caeGroup.Name, 5) = "post_" Then
                ' Insert your code here
            End If
            'Alternative
            If InStr(caeGroup.Name, "post_") = 1 Then
            End If
        Next caeGroup
A similar approach is shown next. The point of emphasis is identifying the groups by looping through them similar to what is above:
        Dim groups As CAE.CaeGroup() = part.CaeGroups().ToArray()
        For Each group As CAE.CaeGroup In groups
            If group.Name.StartsWith("post_") Then
            End If
        Next ' For Each group
The VB program below (and attached as a file) will cycle through all groups in a SIM file and output data to the information window. This was written with NX 7.5.4. I successfully tested it with NX 7.5.4 but didn't try other versions. The check for the group name is case sensitive. I tried groups named "Post_*" and "post_*". It listed out the "post_*" groups only.
' NX 7.5.4.0
' Journal created by golfisd on Tue Apr 12 13:26:24 2011 Eastern Daylight Time
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal88
    Dim theSession As Session = Session.GetSession()
    Dim theResultManager As CAE.ResultManager = theSession.ResultManager
    Dim theLW As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim detailLevel As Integer = 0
        Dim caePart As CAE.CaePart = Nothing
        If TypeOf basePart Is CAE.CaePart Then
            caePart = CType(basePart, CAE.CaePart)
        End If
        processCaePart(caePart, detailLevel)
    End Sub
    Sub processCaePart(ByVal part As CAE.CaePart, ByVal detailLevel As Integer)
        If part Is Nothing Then
            WriteLine(" CaePart:: nothing input ")
            Return
        End If
        WriteLine("CaePart named [" + part.FullPath + "]  has nCaeGroups = [" + groups.Length.ToString + "] tag = " + part.Tag.ToString)
                Dim taggedObjs As TaggedObject() = group.GetEntities()
                WriteLine("  CaeGroup named [" + group.Name + "] nMembers = " + taggedObjs.Length.ToString + " tag = " + group.Tag.ToString + " type = " + group.GetType.ToString)
                If detailLevel > 0 Then
                    For Each taggedObj As TaggedObject In taggedObjs
                        WriteLine("    Member Tag =" + taggedObj.Tag.ToString + " Obj Type = " + taggedObj.GetType.ToString)
                    Next 'For Each taggedObj
                End If ' if detailLevel > 0
            End If
    End Sub
    Sub WriteLine(ByRef line As String)
        If (theLW.IsOpen = False) Then theLW.Open()
        theLW.WriteLine(line)
    End Sub
End Module
Mark
Mark Lamping
CAE Technical Consultant
Siemens PLM Software
(513) 576-2073
mark.lamping@siemens.com
Mark,
thanks you, it's work.
I work on journals in .sim files. I'm a beginner.
Have you some samples of journals to execute in .sim files?
Thanks.
Bastien.
Bastien,
There are a few CAE oriented NX Open examples here:
http://www.plmworld.org
Go to the Communities SIGs and Focus Groups
http://www.plmworld.org/p/cm/ld/fid=67
Then sign up for the NX Simulation SIG (Special Interest Group). That group contains a File Library called NX Open Routines. So far there are 5 routines located there, but internally we've developed many more for users.
Note that you have to be a member of PLM World first before you can request access to the SIGs. Let me know here if you need further assistance.
Mark
Mark,
I have others questions.
Is it possible to include a WindowsForm or equivalent in a journal ? I have find UI block styler but we have not the licence.
I want to create a graphical user interface. Is it possible?
Thank you very much.
Bastien.
Bastien,
I'm told that it is possible. You need to add:
Imports System.Windows.Forms
to the journal. The attached example copies an assembly to a selected directory via standard Windows UI. It runs fine for me using NX 7.5.4.
Should you convince your management to purchase a license of the block styler product, make sure it includes the Block UI Styler application as opposed to the User Interface Styler application. The Block UI Styler application builds dialogs that are consistent with the NX UI from NX 6 onwards. I can't comment on the proper products/licenses, but I do know the preferred application is Block UI Styler.
Mark
Mark Lamping
Mark,
The program you sent me is working properly. I'm leaving tonight on vacation for two weeks.
Can you give me your email address to contact you when I return?
Thank you.
Bastien.
Mark,
I'm back from vacation. I have another question about the journals. Is it possible with a function to retrieve the name of the .sim file and the solution in which we work?
Bastien.
Bastien,
Unfortunately I'm ghost writing here with respect to NX Open questions. My programming skills are dismal at best. Perhaps the NX online help has the answer to this buried in the NX Open for .NET Reference Guide. To get to that launch the online help. Then expand the Automation topic. Go to NX Open and then Open for .NET. There you will find the .NET reference guide.
Another option would be to open a call with GTAC. I'll ping my sources too and post an answer here assuming I get one.
Mark
Mark Lamping
Mark,
I find too in the online help and in the .NET Reference Guide.
Thank you for your answers.
Bastien.
