Offline Pump - Ok to flow?
Hi all,
We have a situation of low pipeline pressure and our main export pumps are struggling to cope.
We have pumps upstream to the export pumps which will be able to cope with the reduced pipeline pressure but the only flow path is through the main export pumps.
Obviously not wanting to damage the main pumps, would it be ok to flow through them whilst they are offline?
A
A
RE: Offline Pump - Ok to flow?
We will design everything from now on using only S.I. units ... except for the pipe diameter. Unk. British engineer
