History of Building Codes
I am looking for some literature on the subject"history of Building codes".Purpose is to prepare a seminar on this topic.I want to explain that code is not only a technical document but is developed according to the local practice,local economic conditions, working conditions in that region etc etc.In most of the cases, its a top-down document,as the things were experienced/practiced first and then codified.( any comments?)
And i want references,like, i heard from my professor, that flat slab construction was first practiced,then the theory was developed and then codified.Where this fact came from? Are there any other examples? i'd like to know if anyone has to share something.
RE: History of Building Codes
Codes are not necessarily "top down" documents.  In the US, codes are as much a result of political wrangling as technical substance.  For each issue, there are those on both sides of the argument for inclusion or exclusion with respect to codification.
I would suggest you check the following site:
http://www.iccsafe.org/Pages/default.aspx
For an international perspective look up london building codes, I believe these were the forerunners for modern codes.
Many of the largest cities had the earliest building codes.  ASCE had some of the earliest codes and general design guides.  Then the various materials associations had their own codes which were used in place of a local building code, such as AISC or ACI.
Also, look up Hammurabi, re: establishing the liability of a builder for a house that collapses.
a234f56,
That was making it a bit too easy for them dont you think!
when i first clicked on a234f56's link, i thought he had uploaded the IBC for all to steal... pipe
thanks to all of you..
a234f56,thanks , i have added this file to my collection.
csd72,yes i have gone through wikipedia page.It has useful content.
From the bit of research i ve done till now,i've come to know that
- Code of Hammurabi ( around 3000 B.C) is the one whose details are known a bit.( Clauses referring to building construction found on wikipedia and on a few more sites)
- In 64 A.D.,Emperor Nero of Rome had some Master plan, related to Fire resistance and sanitation,on which basis Rome was rebuilt after burning.( i am searching if i can get some clauses as precise as written in Hammurabi code)
I am also looking for the code clauses or regulations/ordinances, which were developed after great fire of London(1666 A.D.) and Chicago Fire( 1871 A.D.)
