Apply an indentation from a rigid to a deformable using load control
I am able to simulate the solutions by using a displacement-controlled boundary condition, but I want to use an actual concentrated load to the rigid. The two parts are not in contact but they are close enough that the force exerted on the rigid will touch and deform the deformable part, I have been hinted on automatic stabilization and damping, anyone can elaborate on how to do this?
RE: Apply an indentation from a rigid to a deformable using load control
Is there way to have just one step using a load?
However, why not just move the parts in the assembly until they are touching then run the analysis?
A picture will help with the group's understanding. I hope this helps.
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
