.STP Section Difficulties
Working with an imported CATIA V5 file received as a .STEP. This component cannot be sectioned in a drawing. By this I mean that when I create a section of the view no section lines appear etc. the view does not change as it should.
Can anyone explain why? Is it something to do with .STEP?
Thanks!
Thanks!
RE: .STP Section Difficulties
Open empty part file
Import step file (data from file)
Try
Importet step must bi solid
regards
Wildfire is very nice, if you know,
how work with him
Edit Definition of the Import Feature. Go to the Edit menu and select Feature Properties and Make Solid. Back out of the redefine mode (there's a green check mark somewhere) and see if that worked. Another option that may or may not be available is the Solidify option under the Edit menu. Haven't really figured out why/when one works over the other.
Good luck,
<tg>
