how to isolate the output of a high speed buck converter?
hi, i am trying to isolate the output of a buck converter. the challange is with the current mode sensing of the output.
is there a efficient way to do this?
it is linear tech's lt3694. i am using a transformer to isolate the secondary (output) where i have a split +/- 7v outputs. i have seen some app notes using opto isolators, but they are not very good at high temp.
please help, thanks.
RE: how to isolate the output of a high speed buck converter?
A bit overcomplicated but an idea to spur other ideas...
Z
Keith Cress
- there is a large number of power control ICs on the market, usually optimized for specific topologies and either non-isolated or isolated converters
- for isolated DC/DC swithing frequency for a given power rating usually tend to be lower than for non-isolated design
- the isolated version of the buck converter is not the flyback, but the forward converter
What makes you striving for more than 2 MHz ? What is the benefit you are expecting ?
My suggestion to proceed:
- List the key requirements for your application
- Choose the most suitable topology based on some general text book or a general apllication note
- then search for a specific type of power control IC
