Light gauge girts framing into one another at small angles
Hi
Does anyone have a typical detail when two light gauge C-section girts frame into each other at small angles (10 degrees).
Normally if they where framing into each other 90 degrees then I would provide 2mm bracket (1/8") and 2 bolts thru the web of each girt?
Any help from someone who has experience with light gauge metal building design will be appreciated.
RE: Light gauge girts framing into one another at small angles
Mike McCann
MMC Engineering
