Assembly features: Hole doesn't recompute
Hi
I'm using SE v19.
I have assembly with frame (consisting of several types of tubes that repeat). When I do Holes as assembly features, it is OK when I make holes in one instance of tube, but when I try to make different type of hole in another instance of the same tube type, Hole feature gets red exclamation mark next to it with message: "Associative Recompute Error: Feature did not recompute".
Is there solution to this?
Thanks.
