Allowable Stress during PWHT (after repair)
I am calculating the crane force needed to permit safe 360° PWHT of a medium height, thin-walled vertical steel vessel. I can do the calcs (wind, dead weight), but I am having trouble finding an allowable stress for A285-C material at 1100°F, since that is beyond its permitted max. temp in section II-D.
And are there any other loads I need to consider?
RE: Allowable Stress during PWHT (after repair)
The concern is permanent buckling while at PWHT temperature for a vertical vessel. I would suggest using a percentage of the YS at temperature as a means to evaluate buckling forces. For similar material, the data I have seen at 1100 deg F indicates a knock down factor of 0.4 of RT yield strength.
I'm not sure how to interpret 'knock down factor'. Does this mean I use an allowable of 0.4 x RT YS? Sounds a bit high, but I will consult my EPRI handbook for carbon steels ...
There is no doubt the vessel will be crane-supported, perhaps by two. Is wind still a consideration once you have decided on crane support? I have not yet compared the significance of wind-induced stresses to that of vessel dead weight.
Thanks for helping at this late hour.
Do you have that 1974 paper by Griffin?
My research has led me to API 579, Annex F. If I understand it correctly, allowables are calculated for external pressure in the creep range, and extrapolated into the PWHT range for that short-term situation.
You're definitely on the right track.
I am also attending B&PV Code week in Boston. Perhaps I will see you at the hotel bar......
You might find this paper interesting;
http
I'm still trying to come to grips with the concept of creep buckling; wouldn't that depend very much on the geometry as well as temperature and stress? For example, I expect a longer heated band would increase vulnerability to compressive buckling of the shell.
p.s., while in Boston please don't add any more non-essential variables to Section IX ;)
