JPI PLATE FLANGE DIMENSION
i have to add some piping spool to an existing piping system, then I must manufacture a 28" slip on flange with 40 holes 22mm dia.
can anybody tell me how can I find standard dimensions for Plate Flanges 28" manufactured as per JPI standard 7s-43.
I need BCD, OD, ID, NO. & DIA. OF HOLES.
Thank you�����AG > m i
RE: JPI PLATE FLANGE DIMENSION
but the above catalog only stated the WN and BLIND flange dimensions, I need bore diameter and bolt circle diameter for 28" slip on flange.
Greetings
For ID you can make the dimension acc. Asme flange (dia 717,6mm)
or acc. DIN(EN) dia 721mm bevel 7mm x 45deg.
Greetings
