HVAC for high humidity ambients?
We are working in a HVAC project for several buildings located in Guatemala.
Humidity in the area is extreamly high: up to 80%.
So, latent heat is almost as high as sensible heat, and we are having problems for selecting the equipment. Beside AC loads are higher than I'm use to.
Do anybody has an advise on how to lower the humidity for the buildings, with out having very big AC equipments?
RE: HVAC for high humidity ambients?
By way of illustration, and not endorsement: http://www
and what are the outdoor parameters ?
Also likely to be easier to control and meet setpoints more often.
Worth considering both options anyway.
