Punching Shear on Steel
Hello:
I have an existing steel truss that I am analyzing. The webs and chords comprise of round HSS. The walls of the chord are relatively thin so I would like to check the walls for punching shear. How does one go about doing that? Is there a techincal publication that would be able to assist?
Thanks Again
Thanks Again
RE: Punching Shear on Steel
There is also an HSS connection manual out there (it's not incorporated into AISC 360-05, but I don't believe the one in the 13th Ed. is as extensive) - I believe is't a black book with gray stripes.
http://www.FerrellEngineering.com
Mike McCann
MMC Engineering
