problem with input file in abaqus/distribution command
Hallo
i have a simple square of 100 elements in abaqus and i want to assign different orientations and material properties in each element using iteration.As a first step i have created this input file but i got these errors see attached dat file. I use the distribution command.
P.S. i have checked the file without distribution and it works when i add my distribution commands the errors start.
Please i would appreciate quick responses
