Setting Dimensions - won't re-size drawing
I'm just beginning, and after I draw a rectangular sketch and begin using the smart dimension tool, I cannot dynamically input the dimension after clicking to place the dimension. Likewise, when I do click out and then back on to the dimension, I can input a new measurement but the drawing doesn't actually rescale. It sems that after initially drawing,  I cannot change its size. If I input a new size, it remains blue and underlined to say it is "Not to Scale". How can I change this?
RE: Setting Dimensions - won't re-size drawing
I'm still working on th vocab of the program, but I'm in part. I'm actually in step three of a ordered part modeling tutorial. That's another reason I'm s confused...I've followed the very basic first two steps...
OK, so I forget if the interface in sketch changed much in the newer version, however somewhere up the top there should be a padlock symbol or something so you can make the dimension a driving dimension rather than a driven dimension which it sounds like you may currently have.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
That's just one more problem. If the dimension is unlocked, it still does the same thing. Any other help would be great. Thanks!
