Partlist in Teamcenter integration
I am using NX7.5 with teamcenter 2007. I have 62 parts in an assembly. Only 20 parts are allowed in a sheet of partlist. When I create partlist then three sheets come up perfectly but the last sheet comes up on a blank page which does not have any title block (which show the name of the drawing, designers' name etc).
How can I make the fourth sheet similar to the other sheets?
RE: Partlist in Teamcenter integration
i didn't understand well, but there is a limit in the partlist height, so when after a value, the part list is splitted tht generate blank sheet with other part list.
If you set to 0 the partlist represent all your assembly structure.
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
I have set that limit to 190. Problem is that fourth sheet does not have template which first three sheets have.
thks
I simply deleted partlist and created again and now the fourth sheet has template like other first three sheets.
Thanks fo rur time,
