Grout Beds for tilt up walls
What purpose do grout beds serve? Also how would you figure out how many bags of grout are needed for a building. I am new to the concrete industry. Thanks
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Grout Beds for tilt up walls
The grout bed should be installed and allowed to cure before the building structure is attached and loaded.
To calculate the number of bags, you simply need to perform a volume calculation. Take a 7 1/4" wall panel that is 20' long. The grout bed is 1 1/2" thick (assumed to be an average). Typically the grout bed has a 45 degreed bevel. This means that you have a trapezoid with the top 7 1/4" wide and the bottom 10 1/4" wide. This would result in an area of 1/2*(1 1/2)*(7.25+10.25) = 13.125 square inches. The total volume would be 1.823 cubic feet for the 20' panel. Not sure how much you get per bag, but it would likely be listed.
