Insert User Defined Feature with a Journal
I am using NX 7.5.3 on Windows XP-Pro 32 Bit system.
I am trying to do some automation I was wondering if it is possible to record a journal that inserts a user defined feature?  If it is not possible to record one is it possible to create one through good old fashioned VB programming?
Does anyone have any example journals? Or example programming?
thank you.
