Datum CSYS not showing up in all drafting views?
Hi Guys,
I'm working on a drawing right now of an assembly.  In the front, top, and right view I am able to see the datum csys I created in the assembly.  However, on a custom view I added in the assembly, I cannot see the csys.  Any suggestions?  I'm currently using the show and hide feature to toggle the csys's off and on.  Is there another way?
Chris
NX 7.5
RE: Datum CSYS not showing up in all drafting views?
Hi Chris,
Could you please check for Layer Visible in view option? Which will show/hide specific layer's entities in a view..
Manik
Are you using the master model approach? If so, was the custom view created in the master model file or the drawing file?
