Surface exactly between two other surfaces
I would need to create a new surface, which would be located exactly between two other surfaces. Concretely surface between two blades.
Illustrating images:
- http:/ /files.eng ineering.c om/getfile .aspx?fold er=9db9f20 5-acef-4e3 b-868a-a98 d28605e98& amp;file=z epredu.PNG
- http://fil es.enginee ring.com/g etfile.asp x?folder=3 4447ef2-02 8e-45b5-ba 1b-8a8f033 8d695& file=b.png
I use NX 7.5 and I haven`t found a way how to do it yet. It could be done maybe with using Point Cloud..?
If it can`t be done in NX, could you recommend me another software?
Thank you very much for your advices.
- http:/
- http://fil
RE: Surface exactly between two other surfaces
1. Extract the to primary faces (Insert > Associative Copy > Extract Body - Type = Face, Face Option = Single Face, Select each face > OK
2. Create a Ruled Surface between the 2 faces (Insert > Mesh Surface > Ruled - Alignment = By Parameter, Settings Preserve Shape = Checked)
3. Sew all the faces into a Solid (Insert > Combine > Sew)
4. Now you can use the MidSurface Function (Insert > Surface > Mid Surface > Face Pairs - Select the Solid, Face Pairing = Select the Automatically Create Face Pairs Icon
Done
- http
One point of the required surface is in the following picture. It has to be in the middle of the arc between two points of blade faces.
- http:/
I don`t understand the function Mid Surface. I have tried a various options, but it still does strange things, which I can`t influence.
Is there any other way, how to fix my problem?
Sample
- http
So I want to divide a space between blades, after that I move one part to the second side of the blade and then I will be able to continue modeling.
Then I could count a point cloud of the requested surface.
