Geostar (non-linear) how to release constraints
Hello - please disregard my previous post... I'm hoping that the Lack responses was only my vagueness and not a lack of members using COSMOS anymore!
searching online and finding early press releases, I read that one of the strengths of Cosmos/m / Geostar is the ability to release and activate constraints during a non linear analysis...
Anyone know how to specifically do this?
here is my problem:
I am trying to analysis a 3d beam / truss structure with adjustable linkages...using temp curves to pretension and adjust the structure. getting this all to run to equilibrium is very tricky. I'd like to fix a few points as I bring the structure up to tension - and then release these constraints for the subsequent time steps.
I have time/temp curve defined, and associated the point constraint to this - but as far as I can figure out this just allows me to change it from 0 (fixed) to some value (prescribed displacement) - not completely disable it.
Anyone know a better way to do this?
thanks
Andrew
here is my problem:
thanks
Andrew
RE: Geostar (non-linear) how to release constraints
It's years I don't use COSMOS/M GEOSTAR anymore, but the only feature available in any serious FEA code is RESTART feature:
Suppose that a Nonlinear problem diverged at solution step number 5. Activating restart feature you can change the solution time increment, or some other parameters like loads & BCs. If the restart feature is OFF and you run the nonlinear analysis again, the solution will start from step 1 ignoring previous results. If the restart flag is ON, the solution will continue from step 5.
Good luck!.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
My 2 cents.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
"Node news is good news."
If you do it in one jump you have to use a Dynamic Solution. If you ramp it a little you can get away with a Standard non-linear solution.
You have to activate the time curve before you define the constraint that will be effected by it.
For example executing this:
CODE
TOP
CSWP, BSSE
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
