Sheet name as an associative text in drafting?
Dear All!
I have a question for you in "theme of attributes".
Know somebody a result for the next problem?
I would like to use the name of the current Sheet by a text which is associative. (Can I make it as an attribute?)
For example:
If the current Sheet name is " Drawing_1" on the navigator, I would like to see "Drawing 1" as a text.
Thank you in advance!
For example:
Róbert Boros
Mechanical Engineer
Injection Mold Designer
Hungary
www.bausch.hu
RE: Sheet name as an associative text in drafting?
<W@DB_SHEET_NAME>
as text.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Number of the current sheet: <W@$SH_SHEET_NUMBER>
Total number of sheets: <W@$SH_NUMBER_OF_SHEETS>
Numerator of the sheet scale: <W@$SH_SHEET_SCALE_NUMERATOR>
Denominator of the sheet scale: <W@$SH_SHEET_SCALE_DENOMINATOR>
Size of the current sheet: <W@$SH_SHEET_SIZE>
Units of the current sheet: <W@$SH_SHEET_UNITS>
Projection angle of the current sheet: <W@$SH_SHEET_PROJECTION_ANGLE>
Master Model drawing sheet part name: <W@$SH_MASTER_PART_NAME>
Sheet part name: <W@$SH_PART_NAME>
Note that we may add additional items in the future.
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS PLM Software
Cypress, CA
Best regards,
Michaël.
Yes, I know these attributes.
I tried them, but they are not OK.
I hope Siemens will add this attribute to NX in the future.
Thank you!!!
Róbert Boros
Mechanical Engineer
Hungary
www.bausch.hu
Using a string on your drawing like @Sheet_name should work where Sheet_name = 'Drawing '+ W@$SH_SHEET_NUMBER.
Ben Loosli
I don't there is an built in attribute for the sheet name.
Best regards,
Michaël.
All attributes work fine! No problem.
But, this doesn't work: <W@$SH_SHEET_NAME>
Have you thougt on that?
Róbert Boros
Mechanical Engineer
Hungary
www.bausch.hu
John R. Baker, P.E.
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
