coppy a plane
coppy a plane
coppy a plane
How to copy plane from .asm  to .par file
RE: coppy a plane
By plane, do you actually mean a reference plane or a planar surface?
--Scott
http://www.wertel.pro
RE: coppy a plane
reference plane
RE: coppy a plane
When you are in place editing a part within an assembly.
You can hold the shift key down and select assembly reference planes in order to use them to create sketches or other features within the part.
ST4 also now allows the same thing to be done with the planes on an assembly coordinate system.
Jon Sutcliffe / Solid Mastermind
The Solid Edge Community. Video training sessions, best practice documents, process maps and interactive training http://www.SolidMastermind.com
