Geostar or cosmos/m
Geostar or cosmos/m
Geostar or cosmos/m
hi there -
anyone out there still using Cosmos/m / geostar?
I'm looking for a little advice on "releasing prescribed displacements" in non-linear analysis.
thanks,
Andrew
RE: Geostar or cosmos/m
Yes.
I have done that. Going to have to dig a little as it involves using a particular number for the displacement. Seems like 999 or 9999 did the trick. But I'll have to look.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
You will find the documentation in NSTAR.pdf, p. 5-24 Release of Global Prescribed Displacements. You can keep the constraint forces or release them. The rate at which you release the displacements determines whether you need a dynamic analysis or not.
TOP
CSWP, BSSE
