Shallow Shell Theory
I am a junior engineer and would appreciate if somebody would explain what is the "Shallow Shell Theory" which is the basis for Bijlaard's work in building the Local Stress curves for Spherical and Cylindrical Shells and which was later adopted by the WRC?
RE: Shallow Shell Theory
Basically, its use negates consideration of the shell thickness as a bending member and assumes that it is perfectly in tension. The reason for negating the bending forces is due to the relatively small stresses associated with shell bending. The added bonus is that it simplifies the equations to solve for the shell thickness (or shell stress) by using the Young-LaPlace equation.
I hope this has been of some help to you.
