Transformed section
Transformed section
Dear All
I am working on a transformed section and I have found the attached pdf useful. My only "unknown" is the with the use of (m-1) when assigning a value to the transformed steel-areas. Should (m-1) read 1/m, please?
RE: Transformed section
Michael.
Timing has a lot to do with the outcome of a rain dance.
BA
This is the file again.
As(m-1) = As*m - As
As*m = expanded steel
-As = subtracted steel area
If the section is cracked than no subtraction is needed and the term is just
As*m
I should have expanded the bracket and I may have seen that.
Thanks for all your help.
