Catia V5 macro : units
Hello All,
In the below attached script, text size greater than 7 mm will selected in catia v5 drawing and changed to red color.
In the same context if I want to select text size which are equal to 0.156 inch then how should it be incorporated in the script. I think by default script is considering millimeter units and I need to specify the length in inches without converting 0.156 inches to millimeter.
Thanks in advance,
Guru Charan T
RE: Catia V5 macro : units
Paste the code bellow in a CATScript and run it before what you found on internet (or yo can modify completely the code).
Option Explicit
Dim oDrwDoc As DrawingDocument
Dim oSheets As DrawingSheets
Dim oSheet As DrawingSheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oDims As DrawingDimensions
Dim oDim As DrawingDimension
Dim oDimVal As DrawingDimValue
Dim vc As Integer 'view count
Dim dc As Integer 'dimension count
Sub CATMain()
CATIA.DisplayFileAlerts = False
    Dim Message, Style, Title, Response, MyString
    Message = ("This macro will cchange all your drawing dimensions from current unit to millimeters (except those from main and background views)" &_
                            (chr(13)) &_
                        ""&(chr(13))&_
"   Do you want to continue ?")
    Style = vbYesNo + vbDefaultButton1    'Define default button
    Title = "Purpose "
    Response = MsgBox(Message, Style, Title)
        If Response = vbYes Then    ' User chose Yes.
            MyString = "Yes"
Set oDrwDoc = CATIA.ActiveDocument
Set oSheets = oDrwDoc.Sheets
Set oSheet = oSheets.ActiveSheet
Set oViews = oSheet.Views
For vc = 3 To oViews.Count 'scan all views for dimensions except main view and background views
Set oView = oSheet.Views.Item(vc)
oView.Activate
Set oDims = oView.Dimensions
For dc = 1 To oDims.Count
Set oDim = oDims.Item(dc)
Set oDimVal = oDim.GetValue
oDimVal.SetFormatName 1, "NUM,DIMM"  'pay attention to number format and unit, for inches you can write "NUM.DINC" or "in"
Next 'dc
Next 'vc
End If
End Sub
Fernando
