LED bulbs & UL approval
I need to first confirm that LED lights, the inexpensive kind often found in blinking toys are not all that fragile should they have impacts. I know that incandescent light bulbs used in cars still work fine after a high speed accident and those lights are being replaced by LED bulbs now. Is there a rating spec on LEDs to find out about this, I need them to repeatedly survive at least 50 Gs (which isn't that much really). Second, where can I find them?
Also, do most battery operated (6v) hand held devices like flashlights, portable radios/players etc. need to get UL approval or is UL for higher voltage appliance type products?
Thanks.
Thanks.
Bret
Miami,FL USA
RE: LED bulbs & UL approval
I didn't think that incandescent bulbs had a reputation for surviving high speed car accidents (?). Investigators are known to examine filaments to determine if they were on or off at the instant of impact.
Battery operated toys don't need UL But beware, they may need CE if sold in Europe.
As for where, it depends on what specific type you want. There are dozens of form factors, colors, etc. Radio Shack or Frys would have the canonical LED bulb.
These are a bit pricey, and a little bit less robust because they conform to the glass reflector MR bulb form factor, but they contain 12 SMD white LEDs. You can also search for MR11 LED on EBay and see a few varieties of that configuration.
Just focusing (heh) on white SMD 5050 LED-based products there are thousands of listings on EBay.
TTFN
Chinese prisoner wins Nobel Peace Prize
What problem are you trying to solve? Giving us useful information helps us provide more useful info in return.
Dan - Owner
http://www.Hi-TecDesigns.com
I wanted to be sure I wasn't going to run into problems with them failing before going to the trouble of all the design work. I'm relived to know I can go ahead. I'll follow up on your recommendations and if I have more questions, I'll let you know.
Bret
Miami,FL USA
The application will include being used outdoors in daylight. I need the LEDs to be as bright as possible. They will be powered by a 6v button cell battery. I also need the LEDs to be the lowest possible cost and draw as little an amount of power as possible.
How is the brightness measured - Lumens? Is that the spec to look for?
What would be the category/type name for these LEDs? I know there are new high efficiency ones but don't know if they would meet the above criteria.
Bret
Miami,FL USA
"outdoors in daylight" How much so, i.e., sunlight readable? That would take a lot of doing, but green LEDs might be the best choice.
"powered by a 6v button cell battery" For how long? Button, or coin, batteries are designed for extremely low current draws, which is not usually in the realm of LEDs. At 20mA draw, you might get a couple of hours from a typical button battery.
The "High Brightness" LEDs are generally the brightest: h
TTFN
http
