help needed in finding manufacturer
I need help in finding a manufacturer to fabricate 316 marine grade stainless steel clamps for my business.I have no problem in Spain with the component but would rarther give the work to a uk company. The component is basically a 50mm wide 316 steel rod, 220mm long with a 16mm wide slot in one end to clamp onto 12mm glass.Can anyone help???
RE: help needed in finding manufacturer
However, I'll throw one UK shop out for you, Portsmouth Aviation http://www.portav.com/manufacturing/machining
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
