Sudden Pressure Blocking for Through-faults
Is it a good idea to block Transformer Sudden Pressure Relay for through faults. Please explain why or why not.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
Sudden Pressure Blocking for Through-faultsSudden Pressure Blocking for Through-faults(OP)
Thanks Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Sudden Pressure Blocking for Through-faults
Marmite
Sounds like a problem for EHV transformers.
A false trip of a sudden pressure relay on a through fault could keep a generator off line for a couple days while transformer tests were conducted. I guess we were lucky to not have a false trip.
Never seen, never used some adiitional logic for SPD.
Actually, is not so true, we had problem with false trips of SPD, but Westingause type only.
Sorry, but Im not like this idea, in additional, not always used BI of protective IEDs, in lot of cases used simple LOR.
Problem in SPD, not in the trough fault and gas accomulated.
When through fault currents pass through transformer, windings start oscillating vertically due to dynamic axial compressive forces( copper and press board act as masses connected by springs).This in turn create pressure waves in oil.
Rcwilson,I think you need not worry much in generator transformers as magnitude of through fault current in such transformers will be very much less compared to network transformers.Normally generator impedance will be almost double of transformer impedance and this total impedance will limit fault current 3-4 times full load current and hence winding oscillations will be less.
here in Italy we use SPRs on EHV/HV interconnection autotransformers, without block. SPR and Buchholz realay settings must comply with transformer design in order to not misoperate in case of external faults or seismic events. Thus even if SPR is not inhibited during faults false tripping is actually not an issue.
