Speeds and feeds for high speed machineing
I run a Makino Mag3 with an HSK80 spindle my max Horsepower is 107 at 33000RPM'S I can feed 1000ipm (25400mm/min).  My question is what is the best way for determining a starting point for speeds and feeds? I understand it depends on the application but would like to develop an accurate starting point.  Harmonic's is key I know but I have no equipment available to do that any suggestions?
RE: Speeds and feeds for high speed machineing
Buy a book?
Make a test cut on a piece of scrap, ramp the parameters, and listen?
Start with feed/speed within the capabilities of a lesser machine, and ramp up from there.
... (until something breaks? ; expensive)
... (until edge wear gets excessive?  ; maybe reasonable)
... (until Metal Removal Rate approaches your machine's limits ; did it come with a Help file?)
Mike Halloran
Pembroke Pines, FL, USA
I would thing the MFG would have the info you need.
Every tooling manufacturer publishes information on speeds and feeds.  This should only be a starting point, subject to your actual conditions.  There is no magic formula.
Mike Halloran mentioned the key aspect in dealing with machine harmonics - listen.  Your ears will tell you.  For someone with experience, your machine is singing to you, and you should listen.
The suggestion of a book is good.  I have a book on feeds and speeds for all different alloys and tempers.  Sorry I cannot remember ht name of the book.
Here is what I use so I can figure the speed in my head (as a starting point):
The book value for mild steel in feet per minute tangential velocity equates to approximately 400 rpm for 1" dia using a high speed steel cutter.  So now in your head you can divide the number 1 by the diameter of your work piece or the dia of the cutter depending on whether the work is turning or the tool.
Example:  2" dia cutter;  400/2 = 200 rpm
For carbide cutter multiply by 5;  200 rpm x 5 = 1000 rpm
For Aluminum workpiece, multiply by 5.  Using High Speed Steel
tool bit, 2000 rpm at 1" dia.  For carbide multiply by 5 again;  10,000 rpm for 1" dia.  As mentioned above these are starting places.
