Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Dudes! Great site. You've saved me hours and hours...and I have just started using your site. I've already passed your URL onto my entire company. Keep up the awesome work. Bingo-bango..."
Geography
aneke (Structural)
2 Aug 11 5:40
I'm new in FEA and now using STAAD to check steel deck plates. I believe I have to compare the value of Von Mis against yield stress divided by the appropriate material factor (Ref Code: NS3472). But I'm getting larger values of Von Mis when I make smaller mesh of the plate model. So that makes it wrong to compare the Von Mis to yield stress. How should I do it to make a proper comparison?
JoshPlum (Structural)
2 Aug 11 10:48
It's probably still a proper comparison.  However, FEM results are notorious for having localized stress risers around points of discontinuity.  By that I mean applied joint loads or a defined boundary conditions.
Look at it this way: If you apply a Joint load to the middle of a simply supported plate then what is the stress at the location of the point load?  Since a joint is an infinitesimally small area, the stress at that location would be infinity.
The reality is that the point load is not applied over an infinitesimally small area.  So, it takes some engineering judgement to interpret the results of an FEM model near these points of discontinuity.
SethGuthrie (Civil/Environmental)
3 Aug 11 14:39
Well put Josh.
This is a common issue in all sorts of shell finite element analysis situations, and I usually recommend averaging or integrating the stresses over some nominal width for comparison to any code defined allowable stress level, regardless of the material.
Close Box
Join Eng-Tips® Today!
Join Us             Close
