Spec closes after Save as new revision
Before in NX4 you could have the master and specification open and preform a SAVE AS to new revision and both parts stayed open.
Now in NX7.5 the program forces me to close the spec before a could create a new revision (see screen shot).
If I click OK, the spec closes and a save as is executed, then I need to open the spec again by File - Open ....
Is this behavior intended or is there some setting i need to change so the spec and master stays open during the save as operation.
It's not that I'm lazy but it's just more work always reopen the spec.
Thanks in advance.
Thanks in advance.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
