fusing
fusing
What is the logic of fusing underground primary (12470) system
With 140 amp fuse and not fuse coordination
Thankyou
RE: fusing
You may need to provide just a wee bit more detail to get a helpful answer.
Bill
"Why not the best?"
Jimmy Carter
RE: fusing
Maybe the link explains things, but it is broken.  Sometimes it is not possible to get complete coordination and compromises are required.
RE: fusing
underground primary system being fused at 140amps and
Not being fused coordinated anywhere in system
RE: fusing
Voltage?
Does the circuit feed 1 transformer or 100 padmount transformers?
Upstream protection- relay, fuse, recloser??
Cable size and type?
Load size and type?
Location of fuse in circuit?
Utility system or private industry owned?
Location in the world- UK, North America, Europe, Eastern Europe India, Japan, Dubai..?
This is the type of detail that would help answer your question.
RE: fusing
That is same lack of information with the words rearranged. For anyone to help you need to provide a lot of specific information or have an engineer come look at your system.
