Calculation of Tank Wall Thickness
Can anybody help on the calculation for the wall thickness of a storage tank 98"OD x 216"straight side? The SS304L tank is vertical with cone top and flat bottom at atmospheric temperature and pressure to hold 67% HNO3 (1.41kg/l or 11.7 lb/gal). We had a proposal with 10gauge SS304L for this tank. But not sure if it is safe for tank with this height. Highly appreciate your advice.
Thank you!
bydublin
Thank you!
bydublin
RE: Calculation of Tank Wall Thickness
bydublin
If you use 12F, please use a 'doghouse' shaped manway, not the rectangle 12F recommends. The square corners at the top of a 12F manway generate the highest spots of stress in that tank. I have had multiple cases of Stress-Corrosion Cracking from those square corners.
Thank you!
Manways, side and/or top, appear to be required to me.
What about your State of Ohio and your Insurance company requirements ?
While a "homegrown" tank design may not fail, it will be hard to prove that it is safe.
Storage of deadly/dangerous liquids may require a design certified to be in accordance with a nationally recognized Code or Standard.
NFPA-30 requires tanks that store diesel fuel to be in accordance with a UL, API or ASME code. Is your liquid less dangerous than diesel fuel ?
Yes, storage of large amounts of deadly liquids in API-650 stainless steel tanks is expensive.......
