nx 7.5 posting wrong feeds
OK I called myself searching the forums but with no luck.
My NX 7.5 is not posting the correct feeds.
example:
M8
S500 M3
Z.1
G81 G99 Z-.195 R.1 F20.
X10.
The above feed should be F9. I have 9 as the feed in the operation.
And it is not just this operation. It is happening in others as well. I did not build either post we are using and I get the same result from both and as I dig further the generic 3 axis post that loaded with NX does the same thing. Anyone have an idea?
example:
M8
S500 M3
Z.1
X10.
RE: nx 7.5 posting wrong feeds
Mark Rief
Product Manager
Siemens PLM
I Started a test file with six ops and six diferent tools. Added feeds and speeds then posted. When I posted the test code the speeds and feeds matched the operations.... puzzled I changed feeds posted a second file and the feeds did not update. same result as before.
Now, the status indicator doesn't require you to regen but you have to do it anyways.
Just another NX quirk.
J
NX 6.0.5.3
