HEAT TREATMENT- AIR COOLING RATE
I was hoping that someone could give me some info on how to work out the air cooling rate of a metal to room temperature.
If there is a rule of thumb instead of a particular equation then that would be fine also.
I am tempering tool steel from 500°C and the components are Ø600 x 8mm thick and I was trying to work out how long it would take to air cool to room temp.
Any help would be appreciated
RE: HEAT TREATMENT- AIR COOLING RATE
For an 8 mm wall thickness the part will cool very quickly- you can expect martensite or bainite to form unless you shield the parts from the ambient temperature . Refer to the TTT curves for that alloy. You can calculate the fourier number and /or the biot number and then estaimte the rate at which it will cool down, then refer to the TTT curve for that cool down rate.
By the same token , if you were processing a thick component ( say 35 mm thk) and wanted to form martensite ( as with P91) or bainite ( as with T23) then you want to ensure a fast cooldown , faster than 10 F/min. So make darn sure there is not shielding of the thermal radiaton from the part to ambient.
I have the TTT and CCT diagrams for the tool steel(D2)but I am struggling to determine the rate of cool down from that( I am not familiar with fourier and biot numbers and how they relate to the TTT CCT diagrams)
I basically want to determine how quickly I can put it back in the oven to do a second temper.
This part has already been hardened and quenched to produce martensite
http://web.mit.edu/lienhard/www/ahtt.html
That is, take one out of the furnace and check it's temperature every 10 minutes. That should give you a good cooling curve and allow you to determine the heat transfer coefficients to be able to calculate the time for other sizes/thicknesses.
rp
In theory, you can run fea to get an idea, but as redpicker, testing is still needed to confirm as fea can easily vary from testing by an order.
