Points from a curve
Points from a curve
I need to generate a set of points that follow a set of curves. The points must be equally spaced in regards to a specified axis. The 'Point Set' tool does not seem to be able to do this. The linked picture shows what I want to be able to do: http ://img.pho tobucket.c om/albums/ v412/Stomp y1/pointso ncurve.jpg
Any help is greatly appreciated!
RE: Points from a curve
Set type to Parallel Planes, select the curve as the Object to Section, pick a plane normal to your desired axis, enter the start, end, and step values.
