Problem with history output frequency
Dear all,
I've got an annoying problem with 'output, history'. My requested frequency is set to 1. Unfortunatelly, abaqus writes/saves values for 'output history' at the end of each 10th increment. ('Output fields' works ok). As a result, if my analysis ends at 79 increment I can't see 'output history' at last 9 increments. Is it possible to change this (likely) default setting?
Thanks in advance
Thanks in advance
